Not exactly.....I know that 16198263 is the service equivalent to the 7749. You should be able to find a boneyard one by one of those numbers. FWIW, Scot Sealander (in response to Ludis) commented on the 8707 vs 7749 on the GMECM list back in '99. Here's what they had to say:
Doesn't seem to be. 1228707 was used with Q4's 1989-91. 1228708 is the underhood version (1990-91). What's inside the 8707?
The usual. Very similar to the 1227749, less the A/D mux. Some kind of small SOIC added to the fuel logic. Never did fire up the 'scope to see what it did. Perhaps true alternating fuel firing....like TBI.
Is it a different PCB?
Yes. 79A433
Perhaps a differently populated 730/749?
No, not directly. Just similar.
Perhaps the 8707 adds the quad driver back in.
No. Still has the location unpopulated.
I've only ever seen two Q4's in the junk yard, and they were both 88's with 749's.
I have seen a lot of them here.... Seem to have two different intake manifolds. One almost looks like a set of headers, the other is more like a common plenum. I really don't know anything about them though. The tables are also set up to handle higher RPMs than the usual GM stuff.
HTHs
Michael
