Quickstop [UK]
Combating adversyty.
Sadly, this isn't a rude question
I have a 1/2" NPT hole that is just a bit too narrow. The NPT - AN fitting sticks out too far so I would like to tap the hole a bit wider and thus make the fitting sit deeper. It's for the ATR upper IC I have and the clearance with the heater box is very tight.
Unfortunately, the NPT tap I have is too long so it bottoms out in the hole. I can't drill deeper as that would penetrate the radiator fins in the IC.
Do I need to just cut the tap or can you buy shorter taps for this purpose? I think 1" off the normal length would do it. The AN fitting is about 1/2" too far out but I want some breathing room.
Thanks in advance.
Mark
Thanks in advance.
Mark
