te-44 vs. 20g14
turbotyphoon69
Hey guys quick question, how do the above two turbos stack up agains each other? I know its a rookie question but I am looking to get into high 11s this summer up here in Co. I want to do it with stock internals, heads and I plan on running some alky. Andy turbo suggestions would be great!
TYTILIDIE
METH HEAD
Re: te-44 vs. 20g14
I doubt youre going to pull off 11's with that turbo. Not here anyway. MANDINGO, has this turbo and its nice but Ild say that for hte amount of room itll take up, just go with a 60 or soemthing. If the 20g is behind the 44 it cant be by a whole lot when you break it down to times you can run.
turbodig
Re: te-44 vs. 20g14
From my exposure to them, they're quite similar. The 44 may have a slight edge over a 20g, but it also isn't quite as good with a stock converter.
I'd say neither turbo is good for your goal at your altitude. Both would be ok at sea level, but up there it's questionable.
Something along the lines of a gt35r, or a 52 with a good sized converter would be more to your liking. 63 with a ball-bearing center might be good too. Depends a lot on budget, and what else you have done.
turbotyphoon69
Re: te-44 vs. 20g14
i will have a 3k stall converter, a2a, and stock internals and heads. I am looking to get to 11.8s or so with stock internals and heads. I am mainly looking for advice to get into the high 11s up here with alky, chip, and injectors.
Flyin Ryan
hated cuz he drives fords
Re: te-44 vs. 20g14
yea it's safe to say neither the pte44 or any 20g will get you close to the 11s.. stick with what dig said above
turbotyphoon69
Re: te-44 vs. 20g14
I know I have seen but ONE sytyer with this turbo but I have looked at a t3t4 61mm from garret and considered it. I am not looking to reinvent the wheel, rather just got with a proven syty method. But it has sparked my intrest as another turbo option. Any pros and cons to that turbo?
turbotyphoon69
Re: te-44 vs. 20g14
I have decided to fork it over and go with a gt35r, what external waste gate size do you guys recomend?
