turbodig
Time to make it official....
I've been working on some new WB o2 code for the last year or so.
From the testing that's been done so far, it appears to be a go.
True-WB o2 code for the '749/$58 Sunbird/SyTy ECM.
Features:
AFR field in Datamaster/Diacom will read the real AFR value, not just
some number that you need to re-calculate. IE, 12.5:1 in the scan tool
really is 12.5:1
Fits in the stock 16k code space, so it'll work on Ultimates or other
multi-chip arrangements.
Uses the same wiring and pinout as the previous WB code.
Restrictions:
Currently only calibrated for the DIY-WB, as I don't have voltage to
AFR curves for anything else.
Don't do anything with factory test mode! If you don't know what this
is, you don't have to worry.
Subject to the same DIY license agreement- not for commercial use.
This code cannot be included in a commercial offering. If somebody
already has purchased a commercial chip, and then cons somebody
with a burner to patch their chip for them, that's ok. Basically, this
code is not to be sold as someone's chip "feature". This really hasn't
been a problem in the past to my knowledge, so I don't think it will
in the future. Nonetheless, those are the rules.
Also, with the patch comes a nice, easy way to apply it- Patcher 1.0.
Basically, the syntax goes as follows:
patcher.exe <file to patch> <patch data file>
The patch data file is included, and will default to ptchfile.txt
This will output a new patched file of <file to patch>.pch . Rename this
to whatever you want, and burn away.
Patcher will also detect if you have a larger than stock binary, and will
attempt to patch all the positions in that binary. Meaning: if you have
a binary from your Ultimate, patcher will patch all the positions in that
chip.
You can also select to patch only one position of a binary, if you want.
Patcher has other redeeming uses, particularly if you want to change
data in all the positions of an Ultimate. I used it to disable EGR on all
the positions, would also be good to lower/change the coolant temp
turn-on threshold of things.
While the code has been tested successfully on a few vehicles, I'd like
to get some more test results back, as to how well it's working. Send
DM/Diacom files to: turbodig@yahoo.com
As far as support, there is none, unless I feel like it on that particular day.
Read the readme in the zip file for more details.
Oh, yeah, I suppose I should inform people where to find it:
ftp://ftp.diy-efi.org/incoming/sytypatcher.zip
Later,
Dig
turbodig@yahoo.com
'91 Sy - 11.94@112
Features:
really is 12.5:1
Restrictions:
chip.
Later,
Dig
turbodig@yahoo.com
'91 Sy - 11.94@112
