those with aftermarket engine management
eviltwin
"junkyard syclone"
how are you hooking up your speedometer? ive tried afew things but can never get it to work. thanks in advance
eviltwin
"junkyard syclone"
Re: those with aftermarket engine management
Another question.... Could I run the stock speedo on a separate VSS? Not using the new PCM at all
The speedo isn't hooked to the ecm anyways. Signal comes from sensor on transfer case, into the DRAC (little white box), drac then feeds 2 signals 1 to ecm, 1 to dash.
eviltwin
"junkyard syclone"
so since that is normally ran through the factory engine harness, what wires would i need to hookup from a VSS to the DRAC? thanks
qbnkiller
Conflaguration Specialist
I have the DRAC running my speedo...it has no comms with my BS3. I think to do that, you need to talk with Meaney (if you're gonna use BS3).
eviltwin
"junkyard syclone"
I'm running a 0411 PCM on both my Sy and Ty. I am not using the VSS on the t-case on either. So what wires on the DRAC would I hook the VSS wires to? Thanks
turbodig
Depends on the type of Vss you're using. If you have the VSS on the t-case to use, that'd be the easiest, since you could let the DRAC feed the speedo the right pulses, and I suspect that one of the DRAC outputs could be fed into the 411.
autoaddictions
I used the adapter harness with my big stuff 3. It made the install a snap. As far as the speed o. you still need the white box that was attached to your factory ecu. All my gauges work too.
eviltwin
"junkyard syclone"
I am using the VSS and ISS on the 4l80e for the PCM. I want to use the t-cases VSS to run the speedo. No need to mix the PCM and DRAC with all the VSS sensors I got I guess.
All my gauges work but the speedo. I still have the DRAC box in there. Just need to know what wire(s) I need to hook up then.
Poconojoe
Why aren't you using the speedometer output on the 411 to run your speedometer, it eliminates the need for the DRAC
eviltwin
"junkyard syclone"
Because I don't know how to wire it. I made this thread to find out how to do it, DRAC or no DRAC
