code 44,
Check the ECM wiring connections, particularly terminals 8 and 15. Check for vacuum leakage at the TBI base gasket, vacuum hoses or the intake manifold gasket. Replace the oxygen sensor.
I would have to think vaccum like dubb said. Either do the bike tube trick or spray carb cleaner and listen for it. Did you scrub the motor? Maybe you knocked a hose off? Hows the idle? If you want nick i can come by and run dm on it to see if the o2's lazy.
