turbo specific, hot street camshaft, similar in RPM range to a 412 cam but set up more appropriately for a turbocharged motor. meant for an older s-10 or syty block (will not work in a balance shaft motor) ~.5" lift with 1.5 rockers. cam was installed on a motor we were building, but taken back out for a larger setup. cam is new, never ran. comes with cam card. $250 (add paypal fees and shipping to all parts listed, unless local pickup)
used Baer 12" brakes with PBR calipers. as far as i know these will fit inside the stock wheels for those of you that want bigger brakes but want to keep your stock wheels. this kit is used but has a good amount of pad left. $300 (sold)
JS manufacturing fuel rails, ends are untapped and the injector bosses need to be cleaned before using. brand new as i got them from jeff. $50 a pair. (sold)
JS manufacturing 4L80E output shaft and steel transfercase adapter ring $500
mixed ratio offset race rockers, require guideplates 1.65 ratio offset intake, 1.6 no offset exhaust. V8 set but one is damaged so you get enough for a V6 plus a few spares. used $75
1.6 ratio comp cams, magnum, roller rockers, self alligning, fits under stock and vortec valve covers 1418-12 normally $184 now $100 (these are brand new, but i do not have the original packaging)(add paypal fees and shipping to all parts listed, unless local pickup) (sold)
1.6 ratio comp cams, magnum, roller rockers, self alligning, fits under stock and vortec valve covers 1418-16 (set of 16) summit racing has them for $199, now $125 brand new in the box. (add paypal fees and shipping to all parts listed, unless local pickup)
brand new (i do not have original packaging) 1.6 ratio comp cams full roller rockers (does not fit under stock valve covers) 1318-12 normally $252.08 now $130 (sold)
gilbert propshaft for 700R4 slightly used (roughly 500miles) normally $459 now $300
spare working ECU $100
syty PT44 brand new with full warrenty regularly $923 now $810.00 (this price includes the $69 actuator and gasket)
(add paypal fees and shipping to all parts listed, unless local pickup)(sold)
romulator with a pinched ribbon cable. works fine but if it bends the wrong way it loses connection with ECU. needs repair. (sold)
mitsubishi eclipse 1G big port cylinder head cleaned and ready to go. $100
mitsubishi 1mm over ferrea valves for above or similar head $200
manley valve springs for above or similar head $100
mitsubishi eclipse 2.4 liter stroker crank with matching eagle H beam rods and weisco pistons. crank is used, rods and pistons are new. $600
waterpump and full gasket set.....bearings ect.... $200
e
e
