tool for locking down distributor???
0-60N4
Someone made a tool for accessing the lock donw bolt on the distributor. Does anyone know where to find the post on this or how the tool was made?
Also, with John Wallers Vortec chip, is the base timing still to set at zero?
As you can guess I'm trying to set my timing right now.
sytyguy
Moderated User
Jim........I always had good luck with the distributor wrench put out by Performance Tool. They're a cheaper tool line and the bends in the wrench are a little sloppy which happens to work out better in this case (since the better lines seems to hit on the rail, etc....).
Nonetheless, I took an stud (intake one IIRC) and had an extra nut welded on the very top. This allows you to turn the stud via the top nut and the bottom (original) nut locks the distributor clamp down. With the added height, I can get to the top nut with a standard 9/16 open end wrench.
FWIW, your base timing will be 0 regardless of the chip (Vortec, L35, stock, etc....).
HTHs
Hood
Ian Turgeon
Cascading Inspiration
I swear I got a swivel, socket and extension on this bolt without any real issues. Approach from the driver's side of the intake manifold, angled across to the bolt.
I was able to get the socket to seat fully on the bolt.
Tooky
Serious about performance
You lucky bastards can come with all the wobbles you want and try it on my truck next time I'm setting timing! :evil: :drinking: :lol:
BillC
MAC Tools makes a very nice GM distributor wrench. Don't remember the part number, but it's the 9/16" wrench. Works very nicely on my Ty, never had a problem loosening or tightening the hold-down bolt.
BigAl...
what I found to work best is a 1/4" ratchet with a looooong 1/4" extension with a short 14mm 1/4" socket. The small socket allows you to get under the fuel rail. you don't even booger up the bolt head this way.
BigAl...
DanenGraham
Big in the rear
i just got one of the closedend rachet wrenches, go from pas. side with IC removed, works for me. But your ways seems much ezer.
I might try it.
