torx bolts
mjaugus
Two of the torx bolts that hold the tc cover are rounded out.I was going to dremmel off the heads,pull the cover and worry about the bolts later.Is there an easier way.I've tried lube,heat,various vice grips but can't get a good grip.Thanks,Mike
MikeRenz
not stock
if you dremel off the head and take off the cover.....some of the bolt will be exposed for you to get some grips on.
Tooky
Serious about performance
Are these the same bolts that also hold the steel tranny lines to the TC cover near the downpipe? Mine are all 14 or 15mm hex bolts.. I thought there was like 4 of them. I am wondering if my truck has different ones or if someone replaced them? Where exactly are these torx bolts located?
Methuselah
Torx are stupid.
That being said, I had success with a high speed rotary tool (air driven, the dremel was far too slow to make much of a dent in the bolts).
Once the head was off, and the cover removed, the bolt unthreaded with finger power.
________
Amateur Interracial
Loeryder
He is referring to the 4 bolts that hold the aluminum TC inspection cover on.
The 2 on the drivers side are nearly impossible to get out with the pshaft in there.
If yours are hex consider yourself blessed, torx was GM oem, for some reason.
Matthew Little
tq bolts
tq bolts
If you have a dremal cut a slot in them for a big flat head, and if that does not work just cut the head off, but with a hammer impact set( flat head) it may make it easier to get out and not have to worry about re tapping the hole in some cases.
Methuselah
Re: tq bolts
Re: tq bolts
You'll never have to worry about retapping the holes. The TC cover has through holes and a compression fit to the tranny bellhousing.
So hack away and dont worry about the damage you're doing :)
________
Xjr sportscars
