Two of the torx bolts that hold the tc cover are rounded out.I was going to dremmel off the heads,pull the cover and worry about the bolts later.Is there an easier way.I've tried lube,heat,various vice grips but can't get a good grip.Thanks,Mike
Are these the same bolts that also hold the steel tranny lines to the TC cover near the downpipe? Mine are all 14 or 15mm hex bolts.. I thought there was like 4 of them. I am wondering if my truck has different ones or if someone replaced them? Where exactly are these torx bolts located?
He is referring to the 4 bolts that hold the aluminum TC inspection cover on.
The 2 on the drivers side are nearly impossible to get out with the pshaft in there.
If yours are hex consider yourself blessed, torx was GM oem, for some reason.
If you have a dremal cut a slot in them for a big flat head, and if that does not work just cut the head off, but with a hammer impact set( flat head) it may make it easier to get out and not have to worry about re tapping the hole in some cases.
