Trans temps in DASH for TP
TYTILIDIE
METH HEAD
Is there a way I could use the Trans temps in the DASH in Tuner Pro or Scanenr Pro? What I really want to do is get the temps of my trans to show up on TP or SP. If anyone knows if this is possible PLEASE let me know. I was thinking of utilizing the IC tempsending unit for this but its just a sending unit. I want to also see the temps on the screen.
turbodig
Re: Trans temps in DASH for TP
ECM doesn't read trans temp.
If you have an autoprom you could use one of the auxillary inputs.
SBNova
As for using the IAT sensor- I dont think it would read high enough, without ruining it anyway. Then theres the possibility of being incompatable with hot tranny fluid.
TYTILIDIE
METH HEAD
Theres no blank "extra" ports in the ECM we could use and use a CTS to get the readings? Im willing to do the wiring if its possible at all. I guess I was thinking if there was ablank port, all yould have to do is write a DEF for it and add it to the BIN? But if no port is available, then I guess its a dead end.
turbodig
There's openings, just no code to read them.
Not something we're gonna look at for some time, to be honest.
Convert to an E trans 60e/80e with controller and then you have it.
We actually have just about every input/output slated for something in the future with code59 already, we are even discussing how to add more. Trans temp is WAY down the list, actually not even on the list.
