truck falling on its face
11secty
1 and 2 nd is fine but in3rd it falls on its face and i can watch the boost drop down from18 after it dropped to 10 i let off im gonna run the datamaster on it could some one help me host the file
my wb says im at 14.1 which i know is to lean my turbo is a gt 70 mm i have 50 lb injectors and a custom phill long chip { thanks phill } my plugs cap rotor coil wires are all new
but i think im running out of injector or maybe my fp is going bad
my base fp is 50 lbs
sy#2921
BAMF
Re: truck falling on its face
i would say not enough injector. I have not seen anyone run a 67 or better turbo on little 50#'s
UR50SLO
V6+2=LSXCamaro
I'm running a 61DBB and have 65's. Not sure if I'd run a 70 with 50's. eeeks. Don't stay on it long with those AFR's!
Your EGT's have gota be through the roof!
Be nice to watch fuel pressure with a gage while running (ONE TIME) to make sure it's not a pump/filter/line issue. After that see what the Injector DC is.
Get back with us!! and be carefull!
~Scott
turbodig
Yikes. 14.1 at WOT is destroy a motor territory.
At best, you'd be on the edge of things with 50# injectors. I would make sure that your fuel pump is ok (holding pressure) at WOT. I've seen a 61 run out of fuel with 50# injectors.
Send the file... turbodig <atsign> yahoo.com.
later,
Dig
