The gas should be ok, maybe not the greatest, but decent. I just swapped out distributors, same results! I double checked for spark again too, and its definately there. Anymore ideas??mandingo said:Crappy or tainted gas? Just a thought
Just pulled the TPS plug and same results. I physically swapped ECM's before too with the Sy.. totally different chip and all and same results.Don W. said:OK, fresh plugs might help. However on start-up if you hold the throttle full down it puts the ECM into "flood" mode and stops firing the injs. Have you tried that? Failing that pull the connector at the TPS and see what happens. Drop the ECM and reset all the connectors. Check TDC, #1 on compression then double check timing. However if timing is off you should be getting something.:2cents:
You know, someone else mentioned the return line too. I have a guage mounted on the fuel rail and it reads about 50lbs when I check on it after cranking it over, then it gradually drops down to about 20 lbs after about 5-10 minutes.... is that normal?Don W. said:I'm running out of answers. But what happens if you have a plugged fuel return line? Can the injs hold whatever fuel pressure would result? Put a gauge on it just for the heck of it.
Yeah, I bought the new ing mod for the old distributor; then swaped the new mod to the other distributor I had and threw it in, same results. It sure sounds like it wants to fire, but it just doesn't.TYTILIDIE said:So you did swap IGN MODS with the new dist?
Sy-1177 said:Ok, I got my TDC all set and cap /wires back on. It spins over really nice and wants to fire, but its basically the same as before. WTF am I doing wrong here??? :rant: I really do appreciate all your guy's input here though, without ya'll i'd have taken this piece of shit to the bone yard already! :rotf:
