Re: Truck won't start
Did you check to make sure the rotor they gave you is the correct one? I bought one once for an old car that was supposed to be the right one, and it was about 1/8" too short. Sometimes it would fire and other times it wouldn't. Your problem sounds a little different, but worth checking.
Also, some rotors have a resistor built in, between the tip and the center post - take a multimeter and make sure you have zero ohms of resistance between the two.
The way yours acts, though, almost sounds more like a coil problem. Running fine for a few minutes, then failing, kind of rules out ECM or a sensor (I would think). Double check the connections to your coil.... :2cents:
