tuner pro data log Q's
Osmosis
OK, I'm new to the turbo scene. I used to have tuner cat for my Z28 that was supercharged, but I never used tuner pro.
My wife...YEA, my WIFE came home with a 93 typhoon for me! She actually bought me my dream car! What a woman!
Now, I'm wanting to tune my typhoon. The car runs awesome! i have a Moates G1 adaptor and I have the ultimate chip @ 17.58spsi boost with a 3 bar map, 2 1/2 inch exhaust into a 3 inch muffler.
I plan on replacing the fuel pump to a walbro 255lph pump, AFPR, and maybe a larger turbo. My goal is to get it running 12.2 cosistantly and leave just keep her running. She's got a new engine and tranny with 2K miles on her. I also hot wired the IC pump, new fabricated air dam for the IC, 3 bar map, and ultimate chip.
I want to do some data runs to pull timing out of the car as I run the 21 psi bin and I do see some detonation. Hear some detonation. I want to be able to look @ what my TY is doing and where exactly I have detonation so I can tune my Ty. I have a local gas station that sells 96.5 octane so my fuel is not the problem. I will end up doing a DIY water injection as I did for my Z:)
How do I do a data run in tuner pro? I have looked for hacks for tts data master with no luck
any help would be greatly appricated!
Re: tuner pro data log Q's
The big key is goto the ALDL setup page (F4) and select log for record/playback, you will have to name a file for the first time setup.
Osmosis
tuner pro? I looked and I could not find any aldl setup port? under file, xdf, view, compare tabs? Now, my tuner pro is on my home pc as well as my laptop. Maybe I need to hook up my aldl cable to my typhoon and give it a whirl?
Thank you for the help!:myclone::myclone::myclone::tup:
By the way, my 93 typhoon is xx36
Osmosis
AH, tuner pro RT! I'll give it a try on Thursday when I get home from work;)
Aeroking
e.i.
when you plug your ALDL cable into you laptop find which COM port its connected to.
then in TP.
Tools
- Preferences
- ALDL/Emulation (Tab)
and change it to the COM you're using.
Then to datalog.
Tools
- ALDL/Datalogging
- Setup
In the Setup window click on "Select Log File for Rec/Play" button (on the right side).
- find a folder directory to store your logs in. Then in the Filename box, type in a new filename and click Open. This will create a blank log file. Which is shown in the Datalogging window.
In the lower left corner of the ALDL Setup window is a button for "Connect to ECM". click it, and your main TP window should show a blue box in the bottom center, saying "Connected". Then TP is connected with the ECM.
When your ready to start logging. In the ALDL Setup window, click on the red dot for record, and the black sqaure when you wanna stop. and it'll autosave the log, so you can playback later.
If you're a numbers person, in the ALDL Setup window, you can click on the "Export Selected Session to CSV" and TP will create an Excel file with all your record info in it for you to browse, rather then watching the lines bounce in TP.
I'm taking into account, that you have the correct ADS file loaded. If not, when you first go into the ALDL Setup window, in the upper left, click Browse, and find your ADS file.
Osmosis
Thank you guys for your help!!!!!
How do I change the com I"m using in Tuner pro? My laptop is using com 2 for my ALDL cable, com 1 is my printer port.
I tried to connect, but now I'm getting a mismatched ADS/XDF files?
I am curently using version 11 Ba3barc = 17.58psi boost. I have seen the boost reach 19.5 a few times. I'm using code 59. What gives? I have not had much time to play with Tuner Pro, but I do need to start data loging so I can tune my TY!:tup:
Thank you all for the help!!!
If your using Ultimate chip or any other Program that was written in $58, you will need to $58 ADS (emulation) flles, if you want to be able to edit a $58 file will need to use $58 XDF file. (It will give you an error if you have $59 XDF file when emulating with $58 ADS, but the datalogging will still work)
turbodig
Maybe. Tunerpro wouldn't connect consistently unless you had code59 or an ALDL patched chip.
The timing is too funky otherwise.
