Tuner Pro
Tony Dipatri
I have searched the forums for Tuner Pro intermittant conenctivity problems with errors and when connected to the ECM it jumps all over the place. I have messed with the Baud rate, com settings, latency settings, different ADX files and still the same problem. I noticed when I change the latency settings it has an effect on the connectivity by reducing or increasing the errors but for some reason I can't eliminate them all together.
Has enyone fixed this problem?
thanks
sytyguy
Moderated User
Re: Tuner Pro
Is it just ALDL connectivity, just ECM conectivity, or is it hardware connectivity overall (ECM & ALDL)? Are you using an AutoProm or an Ostrich and ALDL cable separate?
Tony Dipatri
Re: Tuner Pro
I am using just a USB ALDL cable to the ECM for data logging. I am trying to record a log but the connectivity blinks in and out....I can send the log file if it helps
Thanks
Tony
Big Mike
Re: Tuner Pro
Are you using code $58 or $59?
$58 is known to have issues with tuner pro connection and i think there is a bin patch out there for connectivity.
Tony Dipatri
Re: Tuner Pro
Yep hes aware of it....We are trying a few ADX files....Thought maybe it was beyond the ADX file. Just trying to gather some knowledge also.
Thanks
Flyin Ryan
hated cuz he drives fords
Re: Tuner Pro
I had the same issue and it turned out to be my moated extreme Alda cable was failing... I contacted moates and they sent me another out after I sent mine in. Problem fixed so If I was you I would find someone with another alda cable to try out.
Mine works if you need one to test with to rule your cable out
