sytyguy
Moderated User
Been playing around with the Autoprom for the last few days and getting acquainted with Tunerpro. Few things I noticed that seem off in Tunerpro:
- TCC Lower Temp Limit - scalar is off high and unit of measurement is in time.
- TCC Road Speed Upper Lock Limit - scalar seems to be high by about 10 mph.
- TCC Road Speed Lower Lock Limit - scalar seems to be high by about 10 mph.
- Hi RPM Fuel Cutoff Thresh. Hi Limit - scalar is off low.
- Hi RPM Fuel Cutoff Thresh. Lo Limit - scalar is off low.
- Lower MPH for Boost Disable - scalar is off low.
- Upper MPH for Boost Disable - scalar is off low.
- EGR Desired % vs Vac and RPM - % heading is blank and table is scattered.
I haven't been through everything, so I may have overlooked a few. And I may be missing something (very possible with how tired I am), but I tried multiple bins and different xdf files all with the same result. Currently using the newest versions of Tunerpro & xdf file. FWIW, I'm comparing to Promgrammer and actual data readings from my truck.
Anywho, I just wanted to compile a list of things I noticed while they were fresh in my mind.
Hood
Hood
