#3- It depends what I am doing. If your tuning for cruise it might be Kpa, Rpm,TPS, desired AFR, actual AFR, spark advance, knock retard, MAT , and coolant temp. Maybe sometimes BLM or INT.
SBNova was quoting $59 fields :tup: . On Stock Code it is Target AFR and if you have a Wideband with the Wideband 02 patch on your bin, it will display the AFR in that field.
