Tuning Tutorials
sytyguy
Moderated User
Re: Tuning Tutorials
I have RT, bought it last week.
Unusual. Snap a screenshot of what your TunerPro RT screen looks like (print screen >> paste in MS Paint >> save as jpg >> upload to tinypic.com >> post here). It should look like this:
Also verify your build/version number for TP5RT.
Edit: Continued thinking....what happens when you press CTRL+SHIFT+1 in TP5RT? Does the dash open? Does it populate properly? If indeed you have access to the dash and subsequent data, then I'm wondering if a reinstall might cure the issue. What OS? What AV/Firewall suite?
Black Knight
I Glow Therefore I am
Thanks Mike, I uninstalled and reinstalled and now it appears. Maybe I had an older version because the whole thing looks a little different.
I have the .xdf and .adf files for code 58, working on getting the patch from Dig, is there a bin file anywhere for code 58?
b00sted87
I use datamaster to log but im planning on upgrading to the ostrich/g1 adapter. Is it necessary to have tunerpro or can I emulate through datamaster? I feel like i wasted $130 on datamaster when i should have just opted for tunerpro..
sytyguy
Moderated User
Datamaster does not have bin editing or emulation capabilities....only datalogging and real time data viewing. In order to edit the bin file and have datalogging capabilities, you would need Tunerpro RT. Tunerpro RT really unlocks the full potential of the Ostrich for our trucks by allowing you to datalog and edit the bin info at the same time including such features as emulation, data tracing, etc....
sytyguy
Moderated User
Will do. I've been wrenching on the truck a good bit lately, so it's not been that driveable as of late. Once it's roadworthy again (prob this weekend), I'll make some more videos.
On deck: How to Datalog & Emulate
After that: How to Interpret your Datalog
Later on: Making Bin Changes based off of Datalog Info
Black Knight
You are the man :tup:
sytyguy
Moderated User
Can you include a bit on alky AFRs and timing please? :D
Great work Mike!
That will probably one of the last things I'd touch as it doesn't pertain to the majority of trucks. What questions did you have specifically? Tuning for alky/meth/H2O is no different that normal tuning. Depending on what you use, you may have to pull some fuel out at WOT and might be allowed to run more timing at WOT. If using a kit with a progressive controller, you would need to taper fuel down and taper timing up in accordance with the controller's behavior.
The sheer variety of aftermarket options makes it tough to develop a tuning strategy for all kits, so it's really "do what works for your truck". The good thing about alky/meth is that you usually start out rich at WOT and need to lean it out from there. This makes it safer to tune as you don't run the risk of going hella lean at WOT. However, with too much fuel (for too long), it's easy to degrade your plugs, so make sure to give them a chance to "clean up" after each rich run and be sure to check/change them often.
johnboy89
:tup:
