Re: Turbocharging a non-SyTy 4.3
Well, looking at this from a practical standpoint....
Intake, used - $450 (average going rate)
Fuel rail,used - $100
FPR - $100
Injectors - $350
Wiring harness,used - $150
Exhaust manifolds/ x-over -$300
Custom fuel line - $200 (by the time you get all the fittings, etc.
MAP,knock, o2,temp sensors, etc - $300
Fuel pump (In-tank) $100
Fuel pump wiring - $100
ECM -$100
Chip adapter board -$35
Burner and PROM - $100
You're right at around $2500. Now, there will be people who say "I can get x, cheaper..." and you probably can.
But, this doesn't include -
Turbo
Exhaust plumbing
Intercooler + related
All the time you'll spend piecing this all together, figuring out problems,grafting into your dash, gauges etc.
Paying a tuner, if you don't/can't want to do it yourself.
And, when it's all said and done, your TBI motor isn't really set up for boost. The Sy motors that are built for it don't last particularly long. Not to mention, the transmission you have won't hold up, the sy spec trans wasn't even up to the task.
The second list would cost you at least that $3500 additional, if not more. Again, scroungers can find better deals, but a lot of time you end up with parts that you can't use.
The reality of the SyTy market now is such that for another 1-2k, you could have purchased a SyTy.
There have been many that have been down the conversion road before, and they'll pretty much all tell you the same thing- It would have been waaaay cheaper to buy one.
