nello
1.) I've got three gauges in my 3 cupped pillar pod. How do you get all 3 gauges to light up the instument lights without daisy chaining them together which makes each light dim when another is added?
2.) Since use of the factory gauges I do not trust I want to hook up my AM water temp gauge while retaining the factory sender so I don't fubar the ECM. Right now I'm working on a slick little splitter out of brass fittings outta the block, stock senders original location, which you guessed it, splits the one hole into two inputs for both senders read from the same water outlet. ANybody have any brighter ideas incase this does not work out, what are some other options?
opcorn2:
Thanks.
Thanks.
