TWO Questions
nello
1.) I've got three gauges in my 3 cupped pillar pod. How do you get all 3 gauges to light up the instument lights without daisy chaining them together which makes each light dim when another is added?
2.) Since use of the factory gauges I do not trust I want to hook up my AM water temp gauge while retaining the factory sender so I don't fubar the ECM. Right now I'm working on a slick little splitter out of brass fittings outta the block, stock senders original location, which you guessed it, splits the one hole into two inputs for both senders read from the same water outlet. ANybody have any brighter ideas incase this does not work out, what are some other options? :popcorn2:
Thanks.
Re: TWO Questions
I daisy chained them. If you have the proper sized wire, good connections and a good power connection it shouldn't dim.
warmpancakes
Re: TWO Questions
I did the same, you can run a relay and trigger it with the brown wire on the light switch but they are 3 194 bulbs they pull 1 amp a piece tops
BigBadSmoosh
Re: TWO Questions
if you want a reading for coolant and you don't care about the stock dash board why not just replace the stock sender on the drivers side of the block with the one for your temp gauge..
My stock temp gauge didn't work from the start so I used that port for an aftermarket sender and connected it to a gauge in the pillar.
nello
Re: TWO Questions
So how many water temp senders are there? The one on top of the block infront of the intake next to the thermostat is where I'm at. I tried connecting the AM gauge to it but the engine would throw a code after about 10min of driving hense the splitter. If there is somewhere else to connect I'm in, I just don't understand where the location is on the drivers side. thx.
Re: TWO Questions
It screws into the side of the drivers head. The passenger side head might have a plugged off as fitting well, but I am not 100% sure
nello
Re: TWO Questions
When you say good power, would connecting from the "instrument light" port on the fuse box be sufficiant? I do need a good power source but understand very little about electrics so finding the right source has proven difficult. I would like the lights to turn on only when the parking lights are activated and if the dimmer is usable that would be a bonus. Otherwise a I'll use a switch and forget about the dimmer. thx
etriebe
Re: TWO Questions
The sensor on the intake next to the thermostat is for the ecm (leave that one alone, Yellow and black wires). There is a single green wire sensor on the drivers cylinder head between cylinders 3 and 5. that one is for the dash gauge only. if you unplug this one your ecm won't get confused and you can use the hole for your sending unit for the pillar gauge. :2cents:
Re: TWO Questions
I used a blade in my fuse box, its hooked up to go on with the lights. I want to say it works with the dimmer. I don't remember the exact name (it was years ago when I did my guages) of the fuse block blade, but I am sure a search will turn it up.
MikeRenz
not stock
Re: TWO Questions
both heads have a water port for a sender. If your truck is stock/normal, the drivers side head will have a sender in it. Put an aftermarket/gauge sender in your passenger side head. People always use these ports for senders for gauges and electric fan switches
V
Re: TWO Questions
Sounds like you're wiring the bulbs in series. They should be wired in parallel. Assuming that all your bulbs have the same resistance, all bulbs wired in parallel should receive the same voltage.
