...thanks for the reply/update (It`ll be fun to follow your build);
The neat aspect of watching other people`s build, is discovering their insights/intentions.
For example, your Ty has always led the performance/modification/ET field. Can I ask ya
-the change from awd to 2wd seems advantageous if weight, friction/drag, and custom
front suspension work is desired (which all relates to very low ETs, eliminating
transfer case/front differiential and possibly large front brakes). It also
eliminates the tire/wheel/diameter restrictions. Was any of this in your thinking???
-the change from stock frame to tube (tho the pic`s looked as if the rails were still
boxed, but perhaps of aluminum) allows lots of customization (suspensions, engine/tranny
positions, exhaust routing, fuel tank, rollbar) for strenghtening, weight reduction,
and ride height adjustment. Were you at the "limits" of modification with your old combo?
-the change to Twin Turbo, even-fire, larger displacement, larger HP V6 block sometimes implies
higher RPMs (for better hp top end figures), especially with TH400 gear ratios/installation.
Usually, traction isnt viewed as a problem in these cases since large (tubbed)
tires can handle such applications. Was reliability a concern with your last build
if it were twin-turbo`d, or nitrous added, versus a completely new build?
-if the weight target is intended, is serious gutting (removing creature comforts
such as carpeting, pw, ps, a/c, stereo, passenger/rear seats, glass windows,
console, sound deadening and such) required? Sometimes carbon fiber, lexan,
or fiberglass pieces assist in weight reduction (like factory racer muscle cars
where acid dipping, aluminum, and drill holes/minimum optioning was performed)
as well. Are you keeping a mostly metal body with cladding?
If any of my questions is too probing/too informative, please let me know. I
like your careful scheme/plan of modifying (with safety, and integrity) and look
forward to "picking" your brain a bit....grin.
