Typhoon #735...It's a roller!!
Windedv6
Ty n 10s
Well sorta....
We are starting to lay out and weld the new Alston frame. How about the seat!!! :D
John
Windedv6
Ty n 10s
No longer wheel base...the rails are sent long and will be cut ot fit. We just laid them out on the floor for fun and too some pics. The wheels are just proped up for the pic. reverhting will be welded on a jig table after some mockup fitting.
It will have a v6 in it.
John
NOJIMMY
....Cool Picture. Any high-level plans that you care to share? (like...)
-Street/Strip, strip-only, or street/show-only use?
-Emission legal & street-licensed or strip certification?
-Driveline changes from 10 sec mods (like AWD/2WD, single/TT, etc)?
-Weight reduction goals? Hp/Torque goals? Paint/Graphics?
-Suspension changes from tubular control arms/coil overs/link setup?
thanks (and hope all goes well for ya),
Windedv6
Ty n 10s
Street/strip/show...Street licensed and NHRA certified.
Fully built 18* even-fire 305ci v6 TT, 2wd tube chassis with 14 point chromoly cage, chormoly fab9 4 link rearend, mini-tubbed, turbo 400 trans brake, wilwood brakes.
I am hoping to weight 2,800 - 2,900# and trying for 900 - 1,000 crank hp. Paint will match my white Ty.
The suspension is one of the better ones...Chris Alston Chassis Works. Tube a-arms with double adjustable shocks all around.
I will keep some pic coming as we make progress...
John
NOJIMMY
...thanks for the reply/update (It`ll be fun to follow your build);
The neat aspect of watching other people`s build, is discovering their insights/intentions.
For example, your Ty has always led the performance/modification/ET field. Can I ask ya
-the change from awd to 2wd seems advantageous if weight, friction/drag, and custom
front suspension work is desired (which all relates to very low ETs, eliminating
transfer case/front differiential and possibly large front brakes). It also
eliminates the tire/wheel/diameter restrictions. Was any of this in your thinking???
-the change from stock frame to tube (tho the pic`s looked as if the rails were still
boxed, but perhaps of aluminum) allows lots of customization (suspensions, engine/tranny
positions, exhaust routing, fuel tank, rollbar) for strenghtening, weight reduction,
and ride height adjustment. Were you at the "limits" of modification with your old combo?
-the change to Twin Turbo, even-fire, larger displacement, larger HP V6 block sometimes implies
higher RPMs (for better hp top end figures), especially with TH400 gear ratios/installation.
Usually, traction isnt viewed as a problem in these cases since large (tubbed)
tires can handle such applications. Was reliability a concern with your last build
if it were twin-turbo`d, or nitrous added, versus a completely new build?
-if the weight target is intended, is serious gutting (removing creature comforts
such as carpeting, pw, ps, a/c, stereo, passenger/rear seats, glass windows,
console, sound deadening and such) required? Sometimes carbon fiber, lexan,
or fiberglass pieces assist in weight reduction (like factory racer muscle cars
where acid dipping, aluminum, and drill holes/minimum optioning was performed)
as well. Are you keeping a mostly metal body with cladding?
If any of my questions is too probing/too informative, please let me know. I
like your careful scheme/plan of modifying (with safety, and integrity) and look
forward to "picking" your brain a bit....grin.
For example, your Ty has always led the performance/modification/ET field. Can I ask ya.
FYI this is a 2nd Typhoon that he is building up.
