Ultimate chip version?
It's just a six
Super Member
Hey guys,
I am trying to see what version ultimate I have here is a couple pics.
On the label I read C3B1dV8.
I was wondering if I can load that bin into my Moates autoprom, or cannot because it is code 58 & is a 2 bar chip?
Thanks
SY-1193
Re: Ultimate chip version?
Hey guys,
Thanks
You can load that .bin onto the Autoprom...but why? Use a starter .bin
If you really want to: here is a link to http://nwstp.com/ on the left side in yellow is the $58 files for Tunerpro.
You could grab a .bin off of http://powertuneplus.com/ instead of pulling it off that chip, but they are $58/3Bar.(easier)
Here is the thing...that chip has "Stacked" 16K .bins on it you would have to separate them to get the .bin you want.
Once you had that you could load the .bin in. You could stop there and it should run.
If you want to tune it you need the files for tunerpro off of NWSTP site. Note: Ultimate chips are 32pin for switching between the stacked bins - makes it a multichip (normal chips 28pin).
Anything with Code$59 will be 32K and more features. Are you without Wide Band O2 and 3 bar map right now? Is that why you want to use the Ultimate .bin?
It's just a six
Super Member
My logic is, if my Sy runs 12.0 w/the ultimate chip on T2 setting. I am thinking the tune cannot be that far off.
I know it's not perfect & it does need tweaking here & there.
I downloaded Robs 40 lb bin to start with.
I have 36 lb injectors.
I have a LM1 hooked up, just not into the ECU yet.
I use the ultimate w/a 3 bar map sensor.
What do you guys think I should run , the 40 lb bin or the Ultimate bin?
Your thoughts/ideas much appreciated.:tup:
Rick
SY-1193
Rick
Untill you get your WBO2 I would use a $58 3bar off of www.powertuneplus.com
Make sure your timing is the same T2 and you don't detonate (knock).
If you have knock use a T1 .bin from there for now (safer).
If you haven't split a stacked chip before that is probably the easiest way.
Get that WB going.
It's just a six
Super Member
Get that WB going.
Thanks,
so since you are saying to get a Ultimate bin on www.powertuneplus.com , I assume that would be a better choice than the code 59 40 lb bin?
My wideband has been running for years on my Sy, just not hooked up to the ECU, & I am going to hook it up soon into the ECU.
SY-1193
Well, you said you run pretty good on what you have. That would be the quickest way to get it going. Just going off what you said and you asked the question about the ultimate .bin.
You are going to have to spend some time tweaking a starter .bin probably. Tuning it to your trucks needs is the best solution in the end. If you have an APU1 that is the way to go. I was just suggesting a quick solution you seemed to need. You can switch between your Ultimate and Code $59.
Some people have to sneak up on things I guess. (code $59) You have to swim in the deep end sooner or later. Come on in the water is fine.
Maybe the best solution is to stop typing and go stick the pins in your ECU? Go from there. :tup:
You have a version 8 ultimate. I beleive that was the slightly leaner version like v10. Version 8&9 had lower than stock timing which is different than the other ultimate bins, so be aware of this. 8/9 was only produced for a short time period. I can't remember if 8/9 had WBO2 patch like 10/11
It's just a six
Super Member
Thanks Dave.
