Ultimate..... code 42
TurboJunk
questionable
Well i just installed an ultimate today and it idles fine (vacumm is low but anyway).
While driving the car sputters BAD, won't go over 1900 rpm's. And if I sit there and power break the truck to put it under a load it does the same thing.
I checked it numerous times its seated properly, tryed 2 different 3bar sensors (one new one used), theres no wires rubbing or exposed, tryed it in all the settings, i have a SnapOn scanner hooked up and my TPS is working correctly. ***AND I SEARCHED THE FORUM*** BoostedSUV had the same problem but there was no answer.
The truck runs fine with the stock chip back in so i know my moduels good and all my ignition stuff.
i got this chip like 4th hand so i dont the history.
If anyone has any ideas please Reply
CHARLIE
Jimmy
Banned
Re: Ultimate..... code 42
Could be that the chip isn't seating properly.It's a good idea to make a couple of cuts with tinsnips to enlarge the opening of the ecm casing.
Make sure the prom is seated correctly too.
TurboJunk
questionable
Since you say it might not a seated proporly. would it be a big deal if i removed the white tab on the eprom hold down? it gets in the way with the wires..... maybe that holding it up?
Daron
Nuke the tab, just be careful when you pull the carrier out off the ecm should you need to remove it again.
BigBadSmoosh
i hope it works.. if not, let me know...
i couldn't find much of anything either.. asked renz he said he didn't know..
