Ultimate install help
RedlineRex
just installed my radar style ultimate (v7?) w/ 3bar map. everything seemed to have gone well, but when i fire it up ... the Ultimate displays T3-24 and i am not able to select any different modes. if i press both buttons at the same time i get the XXXX display followed by KEY? which tells me the buttons work. anything obvious that i may have done wrong? --paul
the truck fires up fine, but i will not allow it to boost that high w/ 91 octane... :)
SY-1193
Paul,
Your Ultimate is LOCKED in T324. You must press both buttons at the same time "XXXX" will appear then "KEY?" enter your key (should be written in the directions - each ultimate now has different keys). It will then display "OPEN" when you have entered your key correctly. This will allow you to page thru the different settings when unlocked. You can lock your Ultimate in each different setting....sounds like that is what happened in your case...It may have just been locked in that setting. Just unlock it.
Keith
blk97ta
by any chance did you get a key with it ? if so it may be locked to that setting ! you need to have it unlocked so you can change the settings ! that is a radical timing set up (meaning use race gas ) with 24 # 's of boost ! :eek:
RedlineRex
per the instructions i am supposed to press both buttons then XXXX would display, then supposedly OPEN or LOCK will display. this i dont see happening. it goes straight to KEY?. after entering the code in the instructs, nothing happens. i wonder if the code is different from the paperwork. youre right tho, i refuse to drive the truck until i can lower the boost and timing. i'm sure the problem is 100% user error here, still trying to get a feel for all this. --paul
RedlineRex
i'm an idiot...
i'm an idiot...
turns out my prob was that the left and right buttons are backwards compared to the gauge style display. seems to working fine now. thanks for the help...
