Ultimate Jumping Programs
thesyguy
I took my truck out of storage and drove it today. Twice the ultimate chip jumped programs from T1-18 to T3-24 even though it was locked. Anyone seen this problem before?
SY-1193
Re: Ultimate Jumping Programs
Had this before also...
Reseat your chip and carrier to start.
Make sure the shielded covering (the braided metal surrounding the wires) in the black wire is grounded to the ecm aluminum case. Directions show the shielding braid squashed between the case and the cover for the chip on the ecm for grounding.
Also check the ecm ground it is in a crazy place that you would never guess...
The ecm ground wires are grounded to the bolt near the front of the lower intake behind the alternator in the engine compartment. Clean up the grounds there and make sure it is metal to metal there.
This fixed things up for me.
Good Luck!:tup:
jumping while its running for every time you restart? mine always starts a a weird point not on what i shut it off at
Big Mike
One other thing is that your gauge (I had the gauge style) may have a bad button in it. I had this happen twice and both times I had sent my gauge back to get re built. I use to daily drive my Sy and would lock and unlock the Ultimate many times every day and wore the little buttons out.
