So I buy a chip advertised as an Ultimate (not a 10 in 1). I wait to install it because I want to install my gauges first. I now have the gauges in. (All are in, only boost is connected at this time, which I think is the most important. Fuel pressure will be next as soon as I have the adapter.) So I install this chip and the thing runs like crap. It’s like I’m in valet mode all the time. Rev limiter is around 4000 and I’m getting boost spikes (at least one that I saw) to 20-21 lbs. Not only that it’s missing, has part throttle dead spots, you name it just about. This chip has a “selector” that clicks from 0 through 9. I gave up at 4, no apparent change in any setting. Did not run a Datamaster, to upset at the moment.
I pull the chip and go back to stock and I have my old motor back. Runs good but I see that I’m making only 10, maybe 12 lbs boost now that I have a real boost gauge. I’ve inspected the wire to the “selector” and found no apparent damage, which might lead to the valet mode issue.
What gives, comments, ect.
Thanks,
Thanks,
