Re: Ultimate Ver. 7 & Code 59?
The Ultimate uses the following offsets:
0000, 4000, 8000, C000, 10000, 14000, 18000, 1C000, 20000, 24000, 28000, 2C000, 30000, 34000, 38000, 3C000
You could upload eight different code 59 bins while compensating for the offset (0000, 8000, 10000, 180000, and so on....) and get it to work if the Ultimate handles such. Todd, does the Ultimate have a 16kb window only or would it read a 32kb file, if say, double skipped all the way through? For some reason I want to say it's limited to 16kb only.
Moates has a pass through jumper which allows the use of 32kb bin files, so the G3 will definitely work. If the Ultimate could be made to work, then you could correct the display if you are into pic programming (that's what the display uses). Fairly easy stuff.
My advice, get a G3, get a 29C256 eeprom, and pop the G3 into pass through mode. Emulate till your ready, then burn your bin onto the eeprom. Never UV erase again, and a ZIF socket makes eprom changes uber-simple.
Hood
