Re: update: AutoX in Typhoon
Ron, I have refrained from commenting but your last posted video reflected a much improved approach to the course. Just one suggestion; set up for your transitions a bit earlier and try not to brake (or decelerate) while transitioning. The weight transfer added to the existing inertia will add precious time to your overall run because it forces you to run wider AND you are not maintaining your momentum.
Set your entry speed appropriately and accelerate through and out of the curves and you will see a reduction in overall time. As you progress in your development, you can even moderate the brakes in a curve while accelerating to load (weight) the front and increase traction when the Ty begins to push through the curve. All this requires is a proportioning valve, alert focus and practice.
Personally, I would lower the PSI from 40 to around 32 but a lot depends on the track, weather, set-up of the truck, etc. Regardless, 40 is too high!!
Keep at it though :tup:. You exhibit a lot of natural Auto-X talent already but what do I know
