Valve cover breather
syclone rider
Ok i installled the KB air intake with the box a few months ago it only had one fitting to attach the pcv valve up to it (the passenger side one) ok so that left no place for the driverside hose so i removed it and put in a regular push in style breather.Now the truck idles funny every once in awhile and throws a lean exhaust code.Has this happened to any of you guys before?Oh and by the way new fuel pump,filter and no vac line leaks unless its a gasket leaking.
tydye
Banned
Re: Valve cover breather
yea same setup as the kenne bell in mine, i debated to just use a breather for drivers side, i had to get a new elbow to put the hose back connected to the intake , there was a hole already in the intake when i got it but the hose wasnt attached, and idle didnt change when i re inserted the hose, and i get the lean code reading as well in DM hmm what to do.
syclone rider
Im not sure i have tryed everything but replacing all the intake gaskets and im waiting on my vortecs at the machine shop so i dont want to have to take it apart more than once.Are you running a cat on yours?Mines cut off right before the cat= all i have is the downpipe pretty much.
tydye
Banned
yea im running the cat, ( stock exhaust) i have the egr delete plate so i wonder how that will effect things once i change it, buddies egr was blocked pretty bad with all the carbon when he changed his.
syclone rider
I know i cant wait to get my heads so i can take everything apart and clean everything. If you have your egr blocked off with the stock ecu and tune it jacks something up during cruising.
tydye
Banned
yea i have been weary about changing it yet,.. so maybe waiting till i change the ecm, still gonna take it off and see if any build up in there... whats all being done to your heads?
syclone rider
Ported,2.02 ex 1.60 int ferrera valves Ls beehive springs and crower 1.6 stainless rockers redrilled to match our intake and bigger rocker studs ARP of course.
tydye
Banned
ah. have a good shop? im new out here so i'm lost of having any trust worthy work done lol
syclone rider
The guy i have doing mine eat sleeps drinks and craps 4.3 v6.Hes got a chevy luv with a bowtie block and brodix heads with a huge blower sitting on top.All polished, im talking so polished everything looks chrome.Runs a 9.60 with 250 shot just in case.He made down two the final four in pinks all out in AL.His name is Mark Harris.
