Re: Very rough idle, Wb lean, and more "datamaster log inside"
just for shits and giggles.. what else could the problem be?? i checked the oil and it smells like normal used oil, no hints of gas..
I have the tb apart right now, the iac has a tiny vac leak on the plastic side where connector goes.. I pulled it out and its pretty dirty, noone in town has one in stock and there 80bucks. So i will try cleaning it first before i buy one since ive already spent 100 on a distributor that didnt fix issue. As of right now, issues are starts up, idle is kinda all over the place.. Sometimes even dieing out unless i give it gas.. It revs up fine and smooth.. Put it in drive and dies instantly.. If i put it in neutral, rev up to get peddle to drop, then goto drive when it doesnt die, and try to build boost, gets to maybe 2 or 3psi and thats about it and you can just hear the motor isnt happy. I also pulled the wb back out from under dash and everything is still fine and hooked up.. What else should i be looking for?
edit, pulled out the iac valve, cleaned it with brake clean and put it back in. tried to start it but wont run without pressing gas peddle now. i jumped the 2 ob1 ports and i cant hear anything spinning, only hear a click.. click is still there when i unplug the iac valve.
EDIT AGAIN: got dm hooked up, had to keep foot on gas for it to run.. heres what i got
1100RPM closed loop
map at 10.46
vac at 21
lterm/sterm both at 128
02mV at 906/128
BPW at .82/1.5
AFR/CRANK both at 12.7
Spark Advance at 23.2
knock16/knock8 at 1670/6
TPS at 5.1 "Remeber i had to have foot on gas to keep it running"
TPS Volts at 0.73
IAC at 100
And then trying to hold idle at 2000rpm
closed loop
map at 12.64
vac at 19.24
lterm/sterm at 128/124
02mV at 62/128
BPW at 1.10/3.7
AFR/CRANK at 15.1/14.0
Spark Advance at 38.7
TPS at 12.9
TPS Volts at 0.98
IAC at 112
and heres the quick log
http://www.mediafire.com/?ftc1ctl9cxd7pcj
