voltage drop while accelerating.
Owned
Got the truck out of the shop, Drove fine for a couple days then :rant: shit.
expirencing an voltage drop while accelerating, during higher speeds the voltage spikes up and down on its own. Built truck with relocated battery. Funny thing is its been working fine now expirencing this. I checked the new optima yellow top, good. Checked the new powermaster 140 good, voltage regulator good. Connections look good, new wires.
The battery is grounded to the frame, aswell as the starter. I added another ground from the alt to the frame. Don't know what I was expecting,.. Before I start adding more grounds and a possible hot wire from alt to battery, trying to get a good understanding. Grounds look good. I'll check it out again.
While the truck idles I'm getting constant 14.7, While accelerating I get 12.1-12.3, If I let go of the gas it quickly spikes up to 14.7. The ECM is getting around 12.1-12.2. For some reason it felt like the walboro fuel pump was cutting off from low current when its at 12.1 wot. Ordered the racetronix kit to fix that. These numbers were from a scan tool not datamaster. I'm checking actual voltage from the alter tomorrow.
Other things this of concern, night time while accelerating my lights dim, regardess of low or high beams. The second I let of the gas my lights come too.
So I've checked battary, alter, grounds, wires. I'll be sure to check grounds and wires deeper than I already have. Any suggestions from here?
1madgumby
Re: voltage drop while accelerating.
It is the voltage reg. that is built into the Alt. I had the same thing happen & fount it to be the votage reg. It checks out fine at auto zone but when on the truck with A higher RPM it would not work right. replace the whole Alt. & will fix your problem.
Owned
I had autozone and my alternator rebuilder look at it. Both passed. Powermaster 140 alittle over 1 1/2 used. The rebuilder opened it up in fact to examine. Anyone have one laying around? :lol: I hate to order a new one to find out it isn't it. Have to read the return policy I guess.
1madgumby
Have your stocker laying around? go to the junk yard & get A cheap one to test. rob the reg. off of it.
I had this exact problem. Regulator "plug-in" was not fully seated in the back of the alt. Inspect that connection. Also make sure that when you turn the key on you have bat voltage to one of the connections. (The other will be dead - not used AFAIK.) Also check all connections between alt and the truck. This may depend on how you wired your bat relocate.
HTH
Daron
slipping serpentine belt? stretched belt or bad tensioner?
WyoSyclone
Yup, can you turn the alternator beneath the belt? If so, there isn't enough tension.. maybe the wrong size belt? A 140 amp alternator takes a lot of oomph to turn.
turboj91
Bad dio trio will result in irratic voltage especially in times of need ie; after you turn on the lights. Try a diff alt (like aj said)
Owned
Hey guys, tested the alternator direct while giving some load, sure enough pushing out 12.4, alittle low. Ordered another alternator, inspected the belt, feels tight. I'll write back after install. :D
jwaller
Evil Genius/SyTy Guru
it is normal for the Voltage to drop a mall amount 0.5V when at wot it using DM to record. a direct batter check will show that it should not be dropping.
the ecm is powered with an undersize wire and thus the reason for the drop.
BoostedSUV
I use to get a 12.1 voltage reading at the ECM at WOT. That was not actual battery voltage, just ECM voltage due to the demands of the injectors etc. I did the "ECM voltage fix" (essentially running a wire from the alternator to a relay and then to the ECM) and now I see 14.1 to the ECM at all times. It is possible the alternator is loosing output power under a load but most scantools/datamaster read ECM voltage which are known to drop on these trucks during WOT especially with larger injectors
ZavzTy547
Senior Member
I bought one of those chrome 140 powermaster alts and I have the same problem at WOT ( I get 12.1-12.3 at WOT). Let us know if the new alt fixes the issue.
Zav
BMFB
Not to scale
i seriously doubt this is your problem, but ive seen this happen once at work...
a guy came in with an 86 monte carlo, and it needed a rear end, all of the bearings in the diff were bad... So we replaced them, and sent him on his way. he mentioned having a problem with his lights dimming, but we couldn't find anything wrong at first glance.
2 months later the guy came in with the same problem, and upon inspection, the bearings weren't worn out like they would be normally, but they were all pitted. It turned out that his ground strap had corroded and wasn't flowing any current, and the motor was getting its power through the frame, leaf springs, through those bearings and up through the drive-train.
you said you put a new ground strap in, so i doubt that's it, but i thought i would share.
