Owned
Got the truck out of the shop, Drove fine for a couple days then :rant: shit.
expirencing an voltage drop while accelerating, during higher speeds the voltage spikes up and down on its own. Built truck with relocated battery. Funny thing is its been working fine now expirencing this. I checked the new optima yellow top, good. Checked the new powermaster 140 good, voltage regulator good. Connections look good, new wires.
The battery is grounded to the frame, aswell as the starter. I added another ground from the alt to the frame. Don't know what I was expecting,.. Before I start adding more grounds and a possible hot wire from alt to battery, trying to get a good understanding. Grounds look good. I'll check it out again.
While the truck idles I'm getting constant 14.7, While accelerating I get 12.1-12.3, If I let go of the gas it quickly spikes up to 14.7. The ECM is getting around 12.1-12.2. For some reason it felt like the walboro fuel pump was cutting off from low current when its at 12.1 wot. Ordered the racetronix kit to fix that. These numbers were from a scan tool not datamaster. I'm checking actual voltage from the alter tomorrow.
Other things this of concern, night time while accelerating my lights dim, regardess of low or high beams. The second I let of the gas my lights come too.
So I've checked battary, alter, grounds, wires. I'll be sure to check grounds and wires deeper than I already have. Any suggestions from here?
