Vortec head install list.
Sy769
Check the online parts catalog. It gives a part number for a spring kit as you will need new retainers and locks as well.
Make sure the machine shop checks the retainer to seal clearance as I think .500 puts it close or touching on the set I have.
Sy Guy 0024
92 black typhoon said:
Ok i will go with them too then. What springs shoule we run witht this 412?
Get the conicals that Falco mentioned earlier. If I recall correctly, cca-982-KIT from Summit. About $136 for the springs/locks/retainers. They look a little funny installed, as the bottom is a smaller diameter than the top. But they fit with no machining, so that suited me just fine. :D
Corbin
spooldup
Super Member
Ok great!! I will go with them!! Now i guess i just need pushrods. Will the machine sho know what ones to use without the truck being there? The motor is stock untouched if that matters. :D
jwaller
Evil Genius/SyTy Guru
Sy Guy 0024 said:
Are your stockers bent? If not, you should be able to use them. Dunno about aftermarket...
Corbin
do not stock pushrods with any aftermarket spring. you will bend them. your pushrods will depend on rocker geometry. this will have to be determined by the rocker, valve, spring, and stud that you are using. the machinist that assembles the motor should be able to handle this.
Sy Guy 0024
Oh man, where were you guys when I was going through this? :cry:
http://syty.net/phpBB2/viewtopic.php?t=24343&highlight=
http://syty.net/phpBB2/viewtopic.php?t=23851&highlight=
So let me get this straight. Under no circumstances should we re-use the stock pushrods with Vortecs/412/1.5 rockers/982s? From my readings of other posts, I was under the impression that we could get by with stockers as long as we didn't use 1.6s and checked the pushrod slots for clearance? Waller, this is incorrect? If so, my apologies to 92 black typhoon :oops: . I know another guy out there who will be interested to read this...
No one's using stock pushrods with their Vortecs/982s? I honestly coulda sworn someone was....
Corbin
jwaller
Corbin
I wouldnt mind using stock pushrods as long as the head was totally stockthen again I'm not sure you can use the stocklength. I've never used anything stock. BUT if you have changed cams, springs, and rockers then no way.!!!!!!
I did use STOCK cam, STOCK vortec heads and springs, with STOCK pushrods.
When you start changing beyond that (aka cam, springs, etc.) EVERYTHING needs to be looked at carefully.
I HIGHLY suggest converting to adjustable valvetrain also.
Bad geometry will F^%K you up. Just ask my 350 chev that bent pushrods, and everything else it could think of. So much for trusting SOME people to do stuff correct.
0966Sy
Code what?
Soo.. stock Vortec's will work with all the stock hardware besides the rocker's. Which adjustable rocker's are you using JS? Are you using the vortec heads on the stock block internals?
Is this going to be moved to the vault before it gets lost....
100in6
100in6
a set of spacer plates and valley inserts make things easier for installation of intake and eliminates leaks around bad gasket seals and having to fill with bunches of sealer. seals perfectly with felpros and is safer than welding a worked intake and warping it. I use em.
Les
sy1038
yes that is the correct number. It's special order because it's a complete kit. That's why the number is not listed. I triple checked it and was given the number directly by comp cams. The price came from summit. John what spring would you recommend so that we don't have to machine the heads? Do we need to use their lifters or will our stockrs work?
stockers will not work. springs...you've got about 10 choices. use the comp 850-12 lifter. I think thats the right #
JWaller..
Please, why won't the stock lifters work?? I just started my freshly rebuilt motor last thursday :) And it seems (to me) to be running fine?? In it I have the stock lifters installed w. CC -412 cam, (your') Vortec heads, stock rockers and pushrods.
I have some 1.6 magnum roller tip rockers for it, but are going to install them later, w. new matched, hardened pushrods.
I do have some (seemingly false) KR to chase down though. But I was running stock thermostat :eek: Also I suspect my knock sensor, so I have a new one, on order..
jwaller
JWaller..
the stock ones will work. but not for long. myself and 2 others had them explode on us costing us both motors.
they will work but not for ever and esp if you've changed springs to the ones reccommended for the 412 cam.
sy1038
Oops, well I guess that's the springs you used on my heads, so Ive put in the order for a set of the 875's already..
Thanx,
jwaller
Thanx,
yeah sure did. you can run the stockers for a few thousand miles but I'd definatly change them.
spooldup
Super Member
JWaller..
If you go wth 1.6's it was recommended to me to install double springs. just passing the info along....
jwaller
JWaller..
nope. all depends on the spring. their are plenty of choices avail that will allow you to run singles...
spooldup
Super Member
I was told that at 6k rpms's if a spring collapses it's peace of mind knowing that there's a double spring installed.
TURBO TY
run doubles if you want but it is lot easier if you go with a set of comp. bee hive springs, hardened pushrods, full roller rockers , and new roller lifters. why take the chance with the stock crap, so you might save a couple bucks in the beginning but it will cost you more in the long run .
