Walkthrough of Alky Control Kit Install
Re: Walkthrough of Alky Control Kit Install
Where did you guys end up putting your pumps? Since I moved the bat to the bed I "thought" putting the pump forward and at the bottom of the fender well would work. That was the coolest spot I could think of with that nice vent hole in rad support right there blowing on it. Well it turns out that it gets hotter down there then I thought. So I did what you see here. When it's all together there is additional shield that covers the whole works.
It looks cockeyed in the pic because the fender will is out. Normally it would be squared up and mounted to the fender well.
My tank in in the bed. The track didn't like it in the engine compartment. The line runs outside the frame initially then inside the box section and comes out where you see it wrapped in the lower left.
