WB ECM tie in - need help
Maxtor
I'm finally getting around to putting Vout from my WBO2 into the ECM so I can datalog - tired of watching LED's on my techedge display bounce around. Got my chip ready to go with Dig's new code.
During a recent move I have managed to lose my notes - everything I found says to tie into pin "F14" - now I can't find a diagram anywhere that references "F14".
Does "F14" simply mean "pin 14" - or is this some reference to another pin?
leroy
It's between the light green and the dark blue wire on the C311 connector on the ecm.
HTH,
Jim
turbodig
Maxtor said:
Got it. Thank you, Jim.
Also, make sure you grab a good ground on the ECM someplace.
I think B9 on the middle connector is open, if memory serves.
Grounding it elsewhere may result in some funny drift in the o2 readings.
Later,
Dig
myclone
Later,
Dig
Nice tidbit of info as I was gonna use chassis gnd. Thanks
Maxtor
Thanks, Dig. I'll tie in a ground to the ECM next weekend.
So far (with garage testing only) everything seems to work as it should. A foot of snow on the ground is going to prohibit any additional testing for a while. The patcher program for the code change was very easy to use - this thing is really cool.
At idle, the readings on Datamaster seem to consistently average 0.2-0.3 higher than the techedge digital display (observation only). This may be a calibration issue with the display, although I just calibrated the display in November. Any other ideas why the two may be different?
B
Blake
Guest
This is from the other post I just made on WB stuff and the info if from TechEdge itself.
As noted above, the basic WB unit's Vout may vary slightly from the specifications shown here. The stoichiometric Vout of 2.50 may be a little higher or lower (+/- 0.03 Volts) and the free-air Vout may be a little higher or lower than 4.00. It's worth noting that the most important calibration value is to get the difference between the stoic Vout (2.50) and free-air (4.00) to be as close as possible to 1.50 Volts so that the interesting tuning AFR range (AFRs of between 10 and 15 for petrol) are then most accurately represented. When this 1.50 volt specification is achieved, and the unit's offset from the nominal 2.50 volt stoic value is compensated for, quite reliable AFR values can be obtained from the unit.
There are many variables. The WB components on the board, the sensors will all vary ever so slightly, and the TechEdge display itself.
Then you have to consider the age of Dig's sensor compared to yours. He might have been using his for years whereas yours is brand new(goes back to the sensor variable). The sensor's readings will change with age. No way around it.
Also remember that the TechEdge display was a modified unit. According to the documentation, it used a 2.49 volt reference and then used different resistors for low end and high end limits and then balanced them using a 1K resistor. The dots or bars(depending on which you chose) don't even use the actual raw data. They use a lookup table programmed in the PIC.
If you take all the "fudging" into account to make the display work, I find that the tolerances you have shown are very good in fact. Everything considered.
I talked to Dig a while back and he doesn't use the TechEdge so he may not be able to answer your questions on the TechEdge display. Don't mean to talk for you, Dig. Just "putting 2 and 2 together".
None of this was to take anything away from Dig's selfless efforts or Peter at TechEdge. All the info is based on a reference. You change that initial reference ever so slightly and the results will change.
Like I said, with all things considered, I think your end results (comparing the TechEdge modified display and Dig's program modifications) are quite remarkable in that they are that close.
JMO,
Blake
Maxtor
I agree. I also believe two are very close considering all of the variables (especially in the display). My hat is off to all involved - especially Dig. This thing is awesome.
I am surprised the display is as accurate as it is based on the variability associated with its construction and would not have purchased it if I had to do over again. It was kind of a PITA to build for basically the value of a light show. I would like to see someone focus on that thing jumping around while doing a WOT blast. I can usually tell it's 11.x.... but the "x" is up for grabs. Thanks to Dig I don't have to worry about smashing into a tree while tuning my truck!
leroy
I would not call Peter's work at Techedge selfless. Refer to the diy-efi archives for the rest of the story.
Jim
myclone
Jim
Please elaborate as I have read the entire archives and never saw any probs with the DIY WB that I can recall.
leroy
Don't confuse the diy-wb with the Techedge wb.
The Techedge unit works fine, but violates the diy-wb user agreement.
Jim
B
Blake
Guest
I was ONLY referring to Dig. Peter's efforts were far from selfless. Please don't confuse that point. I attempted to get the EFI WB early on and didn't get any response. I believe that it was just because everything wasn't completely set up yet and only certain people were actually able to get them. I used the info Dig sent me to try to get it and never heard from them. I opted for the only other one that was being sold which was the TechEdge. I could have purchased 3 DIY EFI WB setups for what Peter charged me for 1. The two references were to let people know that if they already had the TechEdge unit, the tables were really close(since the design was taken from the EFI group of course). The info was not politically driven in any way. That's a whole other subject and I didn't want Scott's(Dig's) efforts to go unappreciated or overshadowed by the politics of the other issue.
Blake
turbodig
Jim
This was one of the reasons I was reluctant to provide a calibration
for the TechEdge product. I had some involvment in the original
design of the DIY, so it'd kinda be like supporting the competing piracy.
Don't really want to dredge that political battle up again, so I'll just
post the instructions to recalibrate (see other post) and leave it to
someone else to provide. The code is about making the WB technology
useable to the average Joe, and do it economically. Which WB they
choose to use is a subject for their own concience to resolve.
Later,
Dig
