WBO2 & 749?
z28camaro
I'm just curious if anyone here has tried to recode the 749 so that it will work with a wbo2? And if so how did it turn out? I think that would be a nice touch to add that feature to the 749. It would then make it truely equal to the $2000+ aftermarket ECM's.
z28camaro
What I mean is can the ecm be set up to read and make changes off of the wbo2 reading? It would be nice to just completely replace the factory o2 sensor with a wbo2. Is anyone working on implementing this?
Falco
You can run open loop, trash the stock O2 and put the WB in its place. The ECM won't use it's input (beside to put the values into the ALDL stream with a code hack), but you could get the info you want.
HTH,
FLSY2730
Why would the factory not put wide band o2s on, to costly? Is there any cars that come with a wide band o2?
leroy
I think it could be made to run closed loop. It would take some work, and there may not be enough room on the stock chip. There are also some pitfalls with running closed loop at wot. A bad sensor or glitch could be expensive. I think you would need a backup fueling plan, a way of detecting the need for it, and the ability to implement it.
In a way, I already run closed loop. It's just a bigger loop. I drive it, record it on diacom, review the files, make adjustments, and the process starts over.
Jim
Jim
That quote has to be up there on my list of GOOD quotes.
I like it.
Falco
Jim
That's a real good one Jim. :lol:
