I think it could be made to run closed loop. It would take some work, and there may not be enough room on the stock chip. There are also some pitfalls with running closed loop at wot. A bad sensor or glitch could be expensive. I think you would need a backup fueling plan, a way of detecting the need for it, and the ability to implement it.
In a way, I already run closed loop. It's just a bigger loop. I drive it, record it on diacom, review the files, make adjustments, and the process starts over.
Jim
