Re: wbo2 ideal #'s
If we're interpreting your subject literally (ideal #s), then there isn't one. Or, there isn't one I can tell you, because it's different from truck to truck.
If you're looking for "starting point" AFRs, they're different based on:
Gas you intend to run (specific to a who makes the gas, race gas is not all the same)
Engine configuration
Really general info
11.0 -12.8 on race gas.
10.5 - 11.9 on pump
Really, what you're looking for, is the place where knock stops. Your scan tool can tell you that. From there, you're looking for peak power, or lowest ET. Contrary to popular belief, 6 degrees of knock isn't acceptable. Neither is 4.
This is a time-consuming process. If you're not making at least 20-30 passes, you're not even close. (Or, are *very* lucky)
The folks going really fast have been through many, many iterations before they found what their combo liked. Sometimes in the hundreds. I've personally done trucks that had 70-80 bin changes.
D
