wbo2 question
gjp
another post whore
I just hooked up my wbo2. was easy. took me 1.5 hours. the controler has a simmulated narrow band output (0-1v) that can be connected to the ecm. because I have a phil chip in open loop do I need to do this?? Open loop means the ecu does not look at o2 reading??? I should be ok with just the wideband setup??
Also what readings should I look for. It idles around 14.3-14.7 and at 1500rpm its at 13.4-13.8. it moves around alot. I only had it running for a few min. THANKS GUYS.
SBNova
Re: wbo2 question
Thats what my Ty idles at, and it's actually the commanded AF ratio at idle once its warmed up. Your reading at 1500- we would need to know if this was in park, driving steady state, or under WOT. Also, there is no *magic* number that is perfect. A wide band is a tool to help you understand what your engine is doing, and to base your improvements on. As for the need for it when running an open loop chip- I think the lack of a stock sensor may throw codes. You may want to contact your tuner and ask. Congrats on the purchase, I know I love mine.
mrweelr
Re: wbo2 question
I also have the PLX WBO2 and did hook the narrowband output to the ECM. This way, you can see your AFR when datalogging. I posted the wiring info here:
http://www.syty.net/forums/showthread.php?t=29091&page=1&pp=15&highlight=simulated+narrowband
What's strange is I also have a Phil Long 50# chip and injectors and mine idles between 12.5 to 13.3 idling in D. Stock chip idles at stoich 14.7. Phil told me he programmed it slightly rich to get rid of the rough idle these trucks exhibit stock. I have to agree, it idles like a Lexus but I would prefer if it ran cleaner. I'm running v5.50, bought the chip about a year ago. Were some changes made?
gjp
another post whore
Re: wbo2 question
It was in park. I have driven it before with the stock o2 disconected and it did not throw codes. I just want to make sure I can drive it without it hooked up till I get the time to wire in the ecu. The afpr is bad so it runs the best right now at 38psi. at 45psi it misses when the fpr gets hot.
gjp
another post whore
Re: wbo2 question
mine is the plx-250. it says to connect the grey to the ecu o2 wire and add a resistor to simulate the o2 heater?? If not it will throw a code. With the chip it does not throw codes as of yet. It does not say I need a patch or anything for it to work. Anyone use this o2 before?? Thanks.
gjp
another post whore
Re: wbo2 question
hmm. I was told 3 wire is a heated o2. whats the other 2 wires for? The new o2 has 5 wires on it. It was a pain getting that big connector through the fire wall. Luckely I had a rubber gromet that worked good. My 3 pod looks cool at night with the guages there now. I still need to hook up the trans temp sensor. ran the wire to pass front to put a filter there soon. Thanks guys. I am going for a drive now.
gjp
another post whore
Re: wbo2 question
on startup the guage will run slowly for about 20 seconds then it bounces around. even cruzing at constant speed it bounces around so i cant read it well. What would cause this.
SBNova
Re: wbo2 question
Is your gauge reading the simulated narrow band output, or a wide band output? A narrow band O2 cycles constanly between roughly .100 and .900 volts, so it would be hard to get a good reading from that, I think. The slow response when forst started is probably the O2 sensor warming up. They dont read well when theyre cold.
gjp
another post whore
Re: wbo2 question
it reads better now. Here is what it does.
Idle in park 13.5-15
Idle in D. 11.5-13
driving constant speed 14.5-18.5
half throttle. 14-11
WOT 12.5-10 .
When the engine gets hot it still misses and the idle is 17-19 and will bounce to 10-12.
FP is set @ 38psi. I have a new AFPR on order. Thinking it goes crazy when heat soaked.
gjp
another post whore
Re: wbo2 question
yes what? is that normal readings except for the hot idle?
mrweelr
Re: wbo2 question
OK, now I'm not scratching my head anymore. Yesterday, you said your idle AFR was 14.3-14.7. Now you say it reads 11.5-13 in D, which is closer to what I'm seeing with the Phil 50# chip. Mine actually idles between 12.7-13.3 at idle in D, still richer than I'd prefer but at least we're getting consistent readings. You need to get your WOT AFR down lower. 11.8-12.2 is good without alky. With alky spray on, you'll see it drop down to 10-11 range, but that's normal. I'm using setting 4 on the Phil Long chip with 19psi on pump gas (91) and it flies. Get that new AFPR installed and maybe change the fuel filter again for good measure.
gjp
another post whore
Re: wbo2 question
Thanks guys. It runs good right now for about 30-40 min untill it hot. the higher numbers jeremy where when I first start it up. I guess the sensor needs to warm up a bit first. The guage still moves around a bit more then I thought it would. I hope the new AFPR fixes my problem. These trucks have a way to lead you to beleave the problem is one thing and its not.
SBNova
Re: wbo2 question
A miss can give you false rich readings. When you missfire, unburnt fuel can enter the exhaust stream. Just something to consider.
gjp
another post whore
Re: wbo2 question
Found something out today. I drove it for 45 min and noticed I needed gas, After about 8 gallons I heard a hissing comming from the tank. I stopped the gas and when I removed the gas filler gas foamed out. I only had 3/4 a tank. Also When the truck idles with no gas cap the o2 stays at 12-14.5. soon as I put on the cap it starts jummping around. Bad cap. Bad venting??HELP
