gjp
another post whore
I just hooked up my wbo2. was easy. took me 1.5 hours. the controler has a simmulated narrow band output (0-1v) that can be connected to the ecm. because I have a phil chip in open loop do I need to do this?? Open loop means the ecu does not look at o2 reading??? I should be ok with just the wideband setup??
Also what readings should I look for. It idles around 14.3-14.7 and at 1500rpm its at 13.4-13.8. it moves around alot. I only had it running for a few min. THANKS GUYS.
