Weird rattling sound...
NJSERRANO
I've got this weird rattling sound coming from the engine area, maybe alternator, at idle (800 rpm) and just above idle. When I give the truck some gas, over 1200rpm, it goes away. I noticed that there is a broken bolt in the big aluminum accessory bracket that holds alternator and connects to drivers side cylinder head. When we mess with the tensioner pulley, the sound changes. I'll probably try to remove/replace bolt, then replace alternator and or tensioner pulley if it is not resolved. Any suggestions? Maybe I can upload a video...;)
Mprt Kla
Re: Weird rattling sound...
Sounds like the problem I had. I had a noise that would only show up at idle or very very low RPM...but as soon as I gave it gas it would go away. Turned out to just be the alternator.
ziembic
I had something similar on my truck last summer. Keith (sy1193) noticed that it was the tensioner chattering. You could see it moving which correlated with the noise. Replaced the tensioner and bang zoom no more noise.
On a side note, I believe that I am spelling tensioner right, but it is flagged as a mis-spelling by the current dictionary. LOL, I am a geek.
SY-1193
while you are in there....
Check the idler pulley below the A/C. Bearings go bad sometimes.
Check the water pump for play. Bushings go bad. - Also check the weep hole on the water pump for stains or wetness that will indicate a water pump on the way out.
Check your belt for cracks and missing ribs.
Nicks93
It sounds like it may be the belt tensioner. The belt may have to be removed in order to see if it is bad, or else it may seem to be o.k.(that is with the belt on).
NJSERRANO
Thanks! I'll look to hit the simple fixes first, but I've been looking for a reason to replace the alternator with a 200 amp unit.
