Well crud, headgasket?
Running strong again at the track tonight. Felt a little funney (back end moving around a bit) winning the semi-final round. Onto the return road and temps a moving up fast. Pop the hood and I can see bubbles coming into the header tank so I assume another blown head gasket. Make arrangements to leave truck at the track.
What pisses me off is I've been running 22lbs boost with -0- knock. Because it was late rounds I did not run DM. Wouldn't ya know it. But truck was running the same as it has all night so don't know it would have shown anything. All earlier runs were fine. Can post one it you want.
Anyway, will be looking for some different gaskets or something. Using Victor Renz now torqued to factory spec.
No time frame but will post pics when it's apart. At least that will be easier 'cuz AC is removed.
qbnkiller
Conflaguration Specialist
Re: Well crud, headgasket?
Pull your plugs. Do you see any brown glaze on the porcelain?
Good luck Don!
Ya, will haul truck from track today. I really like racing but can't be changing head gaskets like this. Gotta find a cause.
turbodig
Just because the knock sensor isn't hearing it, doesn't mean there isn't knock.
Like Alex said, pull the plugs. I suspect the afflicted plug will be 'washed' by the coolant, but you may get some info from the others.
Head gaskets don't just blow... something causes them to. 95% of the time, it's a detonation problem.
The other 5%, it's a deck or head warpage problem, or bad gaskets/bolts.
Quickstop [UK]
Combating adversyty.
Have you used cometics?
Sorry to hear this Don - you always seem to have a problem but then again you always seem to be racing which is great!
jpalmer
Bad knock sensor? not saying your truck knocks, or much, but throwing ideas at you to ponder. you know better than i would.
Just to touch on what's been posted. I fully agree about the knock sensor detect or non detect. Sensor itself is only a couple of years old and torqued to spec. Racing? Yup, and having fun to. At least until something breaks. Everyone loves the truck at the track but then again they ain't paying the bills. :)
Anyway. Went to the track today to pick the thing up. Big tip of the hat to my employer to let me use one of their roll-backs. At the track I pulled the coil wire and cranked to see if might have hydrauliced. Nope, so plug in coil and fire it up. No indication of a weak cyl while cranking. Run it just long enough to drive it on the truck and back off at the shop.
All of a sudden I'm working (vacation fill in) but as soon as I have time will pull the plugs, do a compression check and report.
Never tried Cometics but will be looking into them.
Thanks for the comments
qbnkiller
The Cometics REQUIRE a very specific head and block finish. If you cannot 100% ensure this is satisfied, choose another gasket (Like the FelPRO MLS ones).
Good Luck!
