What i need to tune with Code59
TYHOGG
Ok AI have read the link to the old post and i want to order the parts i need to start tunning. Are these correct?
G1 Memory Adapter: TPI Etc. (Moates.net)
Ostrich 2.0; The New Bread (Moates.net)
Innovative LC-1/LM-1 (Which one do you guys prefer???)
TunerPro RT (tunerpro.net)
My Laptop
From the discription the new ostrich has a usb cable, so i'm ok there. Do i need to buy a blank chip from and electronics store to burn the new program on, or when i save the old program (atr pitbull) will the chip then be empty.
Thanks,
Adam
Re: What i need to tune with Code59
code59.org should help you out, very similar post details everything there with a little research.
You don't need a "chip" if you run the ostrich. Really I doubt you will ever remove the ostrich once you learn how to use it. Version 2.0 ostrich is killer. I have the very first one to have bluetooth. :)
I personaly hate the LC1 now, after owning one and basically throwing it away about a year later.
I have a PLX now and so far so good.
Loeryder
Anything to be said for the DIY WB?
And do you know if Moates will do an upgrade from Ostrich V1.0 to the newer version>?
I've emailed him twice and heard nothing back.
No he won't do updates. Honestly no real reason to, I did just because I wanted bluetooth but most ostrich can be updated to BT anyways.
The big advantage is the size of the ostrich is now much smaller, there is a cool feature but there is no software to use it yet, and 99.999999% of people wouldn't even know what or how to anyways if the software did exist. (feature is being able to watch the ecm work and when/how it grabs data in real time).
DIY-WB has worked well for many years. If you have one working no reason to not use it. The brand/type of WB is selectable in code 59 (no special hack is needed for any WB).
turbodig
I believe it says right on the Ostrich 2.0 page that older can't be upgraded.
I've had a DIY-WB since the very first board offering. It's still going strong 7 years later.
Still on the original sensor.
$59 likes it just fine.
Loeryder
Which sensor are you using?
Detroit Turbo sent me the Bosch sensor with it.
Its not on the truck yet but I am getting closer...
turbodig
NTK. That's the only one the DIY one would take.
They often came in boxes with a Bosch label.
Is what you got a DIY or one of the manufactured ones?
I was always gonna look into what it would take to convert the DIY to use a Bosch sensor, since they're cheaper. I've got like 10 DIY kits.
WyoSyclone
My Laptop
Thanks,
Adam
I bought the PLX wideband from Detroit Turbo and like it so far..... I would recommend getting the 'Flash n Burn' so you can burn a chip and permanently install it at the end of tuning, rather than having the Ostrich hooked up all the time.. My :2cents: :)
Loeryder
The sensor that came with my DIY is an NTK L1H1 in a Bosch box.
You were correct.
The kit was unassembled, but Myclone assembled them for Scott awhile back.
He made all the harness, wrapped it all, labeled every wire... very nice work that guy did.
The only thing left to do is strip the wires and put the plug for the sensor on there.
turbodig
You were correct.
Yup... pretty much what I have. Mine pre-dates the availability of the actual connectors, had to get a hacked off one. Bruce had a bunch, way back.
I personally prefer the NTK sensor, but they're expensive beasts.
2kwik4u
Resident slow guy
Dig, I've got at least one NTK sensor sitting in a drawer looking for a home if you want it. I can bring it to nationals if you are going to be there, and I'll trade ya for a beer. Or if you want to cover shipping ($2 maybe?), I'll send it your way before then.
