What would cause AFR fluctuation?
TYTILIDIE
METH HEAD
On a truck I am tuning, under boost, AFR's are running in say....the 10's, then suddenly, they will either dip down to the 8's or shoot up to the 13's and sometimes 14's. They are spikes across the board and they are fairly frequent. I am not sure what to make of it. At any rate, I am thinking it is a glitch but would like a second third or fourth opinion.
leadfoot
Re: What would cause AFR fluctuation?
What WB are you using?
Could be a bad connection/ground or the O2 sensor on the way out.
Did it always do this or just started?
TYTILIDIE
METH HEAD
LC1, go figure. I was just looking at files from March and it did it then too.
syclone rider
Man im using a Plx and it does the samething i try to tell myself its just the guage is wrong but im not sure.
Quickstop [UK]
Combating adversyty.
Then you need two gauges, possibly with another wiring harness and ECM spliced in to the connections to verify if it's the guage. Lots of work but as a diagnostic tool it would be pretty conclusive. Then you could either average the values or prove the wideband is erratic.
Any other symptoms of the truck? Too rich could be a leaky injector and then the ECM pulling fuelling could cause the lean condition....
WyoSyclone
What are you using to log?? TPRT v5 perhaps?? There seem to be a lot of datastream errors with v5. DM usually has a few, but not a lot. It's probably just ALDL dropouts that you're seeing.. shoot me over a log and I can take a look if you want.
Aeroking
e.i.
are you seeing the spikes in the gauge, or on the log, or both?
if you're seeing it on the gauge and log, then its not an ALDL connection problem.
TYTILIDIE
METH HEAD
Yes, I see it spiking on the gauge and the log. Personally I am stumped about the whole thing.
WyoSyclone
I just looked them over and sent you an email Mike.. definitely not an ALDL problem. I gave you some things to look at in the email.
TYTILIDIE
METH HEAD
Rob, just emailed you back. I am pretty sure this is not a fuel pump issue. As for alky, if it is the alky causing it, I dont see why. Nozzles spray great, grounds are perfect. It also seems like it starts to have the issue before the alky even comes on. Im running out of ideas here.
TYTILIDIE
METH HEAD
Injectors are new, Motron 65#ers.
SY-1193
When you play back your DM file look at voltage
Double Click on one of the color letter plot items in the bottom right.
A "Engine Plot Items" window will pop up and select "Ign Volts".
It will chart the voltage and you will be able to see any problems.
Just one thing to check...voltage dips can make everything whacky. (check grounds also as someone else mentioned).
TYTILIDIE
METH HEAD
Voltage is smooth and stable. BPW is pretty tame too. Its a nice smooth rise.
