Wide Band O2 damaged?
When I start my truck up initially, I didn't wire up my WB02, but the sensor was in the exhaust stream. I ended up having some problem starting my truck up, battery/alarm/timing issues.
Anywys, so I was doing code $59 today on the idle and I couldn't get my afr above 11.0:1. It just alway stayed in the 10's, I made enough changes that it should made a difference, my truck is emulating. Did I damaged the Wide Band O2 sensor or is it just reading funky from my fouled up plugs. I was going to check the WB 02 vs my NB 02, but I was having problems getting ALDL data :rant:
turbodig
Re: Wide Band O2 damaged?
Pull the sensor out and re-install. They're ground finicky.
Also, try the sensor in the exhaust of another vehicle... see if you get the 14.7.
Had a wb in the GN read 9:1 at WOT, whereas before it had read in the 11.x:1 area. Put a new sensor in, went back to normal readings.
Put the "bad" sensor back in, and it was back to normal. Go figure.
Poconojoe
The instructions to mine said not to expose it to the exhaust stream with out power and to power it up, in air, before useing it the first time. Mine is an Innovate LC1, which also uses the LSU4.2 sensor. The warning also tells you, will be damaged very quickly if you run it unpowered in an exhaust gas stream
Update: my WBo2 works. My problem was my emulator wasn't working properly. My hard drive went last fall and I didn't reload the Romulator software. Since I didn't reload the software my romulator wasn't set for 256K E-Prom. Anyways, it fooled me because it said it was connected and it had the current base 60# program with my 160 fan turn on settings. I have loaded that up to my emulator last year.
