Wideband o2 sensor placement
turbodig
Re: Wideband o2 sensor placement
Where is the best place on the downpipe to place the Wideband o2 sensor?
It's not fussy, the only thing is to not have it on the bottom 1/2 of the pipe.
I've got my WB bung about 2" behind the stock one. I've seen other guys put them down by the trans.
They both work.
Gbodydriver
So by bottom half your saying it has to be on the top of the pipe to avoid moisture I assume. Is that correct?
Also can it be mounted without removing the Downpipe?
Norm
Yeah, you can drill a hole in the downpipe and weld in a bung. Mine was up top right beside the sensor. Just unplug teh electronics before you do the welding.
BoostedSUV
What they said, anywhere before the cat will work. Mine is mounted down under the truck right before the cat. I used a clamp with an O2 bung on it rather than welding one on.
Gbodydriver
So you removed the intercooler and drilled the wideband near the stock location? Are you still running stock intecooler?
Gbodydriver
I saw those clamps online last night. What did you have to mod to make the clamp fit?
Norm
I did mine when the downpipe was out of the truck. No intercooler now. It's LS powered.
syclone rider
Man dont be scared to take something apart just take the downpipe off and weld it or take to somebody else and let them weld it!
If he has a stock downpipe and cat, the only ways to get the stock pipe is to cut off the cat or cut the down pipe (or pull the motor)
Gbodydriver
yes, na ls 1 with a 4l80e tranny.
Wow I always wondered if anyone had tried that out.. Seemed like a good idea and also very reliable... How do You like it compared to the stock drivetrain?
Mod? Nothing, drilled a hole, put the clamp around the downpipe and screwed in the sensor. Works great and no leaks
Oh ok I get it. It elimates the welding
