Wierd Idling Issue
Truck sometimes starts right up and idles fine.Sometimes the idle does not want to come down below 1000. Yesterday, I let it run for a while and the idle finally dropped down to around 850 or so and was smooth but if you tried to give it any gas, it would not take any at all. If you tried to give it any at all, it would pop in the intake and would shut off.
I have replaced the ignition module and the iac but did not make any difference. Then yesterday while it was running in the weird mode (smooth but would not take any gas) I tried changing the settings on my ultimate chip. I could scroll to the security mode while it was running and it would not shut my truck off.
Later, after running for a while, it would switch back to idling ok and I could rev the engine and everything was ok and the security setting on the chip would cut the truck off. I'm stumped. Today, I am going to pull the ecm and check the plugs and see if the chips are plugged in all the way. Maybe over the years the chips have worked their way out a little from all the rough roads. I doubt that is the case but gonna check anyways. Maybe my ecm took a dump.
I do not have any test equipment. I have data master on my laptop but no cable and no knowledge on how to even use it. Car shows and nice weather is on the way and I am desperate to get her back on the road again. Any help or advice would be appreciated. I would even pay someone with the knowledge to help me diagnose before I put her on a trailer and make an appointment with Sportmachines.
Re: Wierd Idling Issue
Mine acted a lot like what your describing. Only the RPM's would not get below 1500+/-
It turned out the fuel pump and the ECM decided to die together.:roll:
I think my fuel pump is ok. Fuel pressure is good and rises when you rev the engine. I drove it a couple days ago and fuel pressure went way up to 60 or more when under boost. I was getting a lot of pinging though. That has never happpened before. I was even spraying 100 percent when it was pinging.
Sounded like a eggs frying in a pan. Got out of it immediately and will stay out of boost until problem is solved. I can't even drive it now, anyways.
Windedv6
Ty n 10s
Double check all your vac hoses for leaks. Has your vac changed at idle from what it was previsiously?
Check fuel pressure for problems. Hope you didn't hurt it from the detonating. Stock pistons can go fast. Good luck.
I got out of it immediately. Truck holds a steady 20 vacuum at idle. Went over all vac lines visually and with can of carb cleaner and starting fluid and found no leaks. The part where the ultimate will not shut the truck in security mode has me stumped. In the middle of yanking the ecm right now and looking for the brown/tan wire behind the carpet. Theres a harness comming thru the fire wall but havent found the brown wire yet. I unplugged it years ago when checking my timing and forgot where it was.
Big Mike
Re seat your chip on ecm, check your ground wires for ecm the one located on stud for lower intake manifold near alternator.
Big Mike
What exactly did you do as far as checking grounds, did you look at them or use a meter to ohm them out? Also what ultimate chip do you have gauge style of radar?
Have you tried comparing a new/other Oxygen sensor?
Just a thought as I've heard a lot about them causing trouble if they get dirty, though it would maybe do it more consistently.
Fwiw, I blew loads of soot out of my engine running a bottle of Wynn's Injector Cleaner through it. Wouldn't do any harm and you'd possibly get better idling just from that like I did.
Mine had really bad compression and some loose sparkplugs but still, it made a massive improvement though.
If you do need Datamaster info, it might be worth going here http://powertuneplus.com/
I'd recommend it to every SyTy owner as a must read tbh. especially if you're getting any knocking. Could be soot clogging up your system that's causing hot spots and detonation but if nothing happens when you give it throttle, it could be extreme knock retard. Again, just some maybe's.
It could even be mis-sequenced spark leads. We've all done it. The 'pop in the intake' sounds more like a basic timing problem but I'm sure these chips can mimic all sorts of wonderful "special effects"!
Oh, by the way, (and this is to all stock shortblocked owners), don't trust the timing marks on the stock crank dampener as they are known to 'walk' or slip round after a while. It's only a steel outer ring pressed onto a rubber type band, afterall and they age and have even been known to come off. My first timing mark wasn't even visible, it was so far round from where it was supposed to be at No.1 TDC. This was after swapping all the distributor cap plugs to the correct locations. How the previous owner got it running, I'll never know but he said that they copied the exact manual positions. Must have been the wrong manual, I guess!
My o2 sensor was changed about1,500 miles ago and my plugs are new. A/C Delco cr42ts. Wires have less than 5,000 on them. Taylor 8mm. Cap and rotor has less than 1,500 miles on it also. I checked over all of these items and they look ok. My truck only has 26k on it. It's mint and I am really careful when I work on it and double check everything I do. As far as using datamaster, I have it on my laptop, but have no cable and no experence with using it. I would not even know how to turn it on and get started unless someone showed me how.
My spark plug wires are on right. Runs smooth as can be when it wants to and revs up ok until it goes into some funky mode and then everything happens. It could be idling nice and when you put it it gear, it shuts off but cranks back up. I hate to half to start buying replacement parts/sensors/ecm/ and distributor if I dont need them.
That's what happened to mine; I'd get it starting and running ok and it would immediately stall when put into drive. Like I say, mine was probably due to poor compression as I found 3 sparkplugs loose.
However, at a few degrees twist of the dizzy, it would take forever to start but when it did, it could be driven, no problem. I just couldn't get it to start reliably and pull away so I gave up and stripped the engine out. Glad I did too.
vinnieTy
TY # 1889
Fred put the stock chip back and see how it goes. With an issue coming and going especially when you said putting the ultimate in security mode it runs is weird. I would have said o2 sensor next but you said you changed it 1500 miles ago. Just out of curiosity how did you know it was bad?
I had to change the o2 sensor because I could not get the old one out of my stock down pipe when I converted to the jsm 3 inch pipe. When the truck is running, I can scroll thru the ultimated settings and its supposed to shut off when you put it on SEC, but does not happen when running weird. I unplugged the ultimate and plugged the stock chip back in and it still did not run right. Maybe because I did not put the 2 bar map sensor back in. I need to look around and see if I can find it.
What I really need is for someone with more knowledge than me to take a look at it with some test equipment, but have not found any takers yet.
vinnieTy
TY # 1889
Yes that is correct you need the 2 bar with the stock chip. Get the 2 bar installed with the stock chip and go from there. If i was closer i would loan you my 2 bar to test even my ecm if you needed. As for the usb cable to connect your laptop for datamaster i might have an extra. If so i will ask for your address and mail it to you but again let me check when i get home. As for learning how to use datamaster i just read the instructions a few times and searched on the forum datamaster and kept reading. I know its not going to be enough but at least you can share your logs and post them up for others to help out. I have the document but i have no idea how to post up a PDF so im going to email it to you.
